ajit.nayak87 Posted September 7, 2015 Posted September 7, 2015 Dear all.I am working with research project .I wanted panel, inverter database for calculation& selection process. From Pvsys how can get all competent data base.I have followed below steps open pvsys-> tools->component database -> panel database -> selected multiple panel list -> choose export option-> i got the message as below. when i checked the path. i found only single component being recorded. How to get all component data base for panel & inverterThere is another path where i get details but its in .PAN extensions . how to open .Pan extention file.C:\ProgramData\PVsyst\Data\ComposPV\PVmodulesIs there any method i can get all database for solar panel basic data used for calculations?? Please suggest me method to download it.I am using pvsys 5.42 evaluation versionIn help file in component.xls it said thatTransferring a component from PVsyst to EXCEL : In PVsyst, open a component. Click the button "Export to Table". This will store the whole module data into the clipboard. Go to EXCEL (or open a text file in a text file editor) "Paste" the contents of the clipboard as an Excel line. In EXCEL, if the data are not well dispatched in cells, please use the menu "Data"/"Conversion", and check the box "Separated" / "Separator Semicolon". pvsys export
ajit.nayak87 Posted September 15, 2015 Author Posted September 15, 2015 Please let me know how can export pvsys panel & inverter database into excel
André Mermoud Posted September 16, 2015 Posted September 16, 2015 You cannot export the whole table at a time. You can export a selection of components using "Databases > PV modules", When you choose the button "Export", you have the opportunity of selectring several devices using the Shift key. You will find a template of the EXCEL file "Components.XLS" for receiving these data in c:\Program Files (x86)\PVsyst6.xx\DataRO\PVsyst6_Data\User\
ajit.nayak87 Posted September 30, 2015 Author Posted September 30, 2015 Yes I found template of excel file . But i found i could not able to get Selected Pv Module.what is use of choosing multiple pvmodule when we cant extract data.I am using pvsys 6.3.9 latest version. In excel sheet it said you can extract multiple pvmodule . Do you know how the process it. I could not able to understand
André Mermoud Posted October 17, 2015 Posted October 17, 2015 When you are in "Tools > PV modules", clicking "Export" will produce a message explaining that from now, you can select several modules at a time (using the Shift key, as usual).
