Tokoyoshi Posted August 21, 2015 Posted August 21, 2015 I have a question. I am running a simulation using a Solectria Central Gride Tie Inverter SGI 500-480V using Canadian Solar 315.Mix Orientation of East and West.148 Strings of 12 modules91 strings facing East57 Strings Facing WestLosses:Osmic Losses 2.0%Module Quality: -0.4%Mismatch losses: Power Loss at MPP 1%Soiling Loss: 0.5%After the simulation, my osmic wiring losses is ridiculously high -81.9% (see attachments)Please advise & thank you.Report 2Report 1Inputs
André Mermoud Posted August 21, 2015 Posted August 21, 2015 There is probably a problem in your system's definition, that I don't identify. Which version of PVsyst are you using ? Please send your whole project (using "Files > Export projects" in the main menu) to support@pvsyst.com
Tokoyoshi Posted August 25, 2015 Author Posted August 25, 2015 I figured out the issue. I believed that it was the old version of my PVsyst. I updated it to V6.39 and the problem was solved.
