PVsyst 6.39 crashes when tries to calculate teh Shading Factor tables
Hallo,
I am trying to test PVsyst 6.39.
I have imported a 5 MWp system without problems from HELIOS 3D, but every time the program tries to calculate the Shading Factor tables, it crashes.
Hereby my System Property:
Processor: Intel® Core i5-2520M CPU @ 2.50GHz
RAM: 8,00GB
System Type: 64-bit
Operating System: Windows7 Professional
What´s happening?
I am using Helios 3D-2015.
Thank you for your help.
  • 3 months later...
Has the problem been solved?
I'm facing the same issue here.
PVsyst also crashes when I try to enable the Realistic View.
I have the same set-up described by Valerio Solar, but with windows 8.1.
During the simulation PVsyst uses about 1836MB of RAM and crashes.
  • 2 months later...
If anyone is still having this problem I had the same issue. I found that the programme runs if you leave the computer alone after hitting "table". For a larger shading model you might need to leave the computer untouched for many hours after starting but it should work.
By leaving the computer alone I mean do nothing more than move your mouse while it's computing, even clicking with the mouse can crash it. It's inconvenient but has worked for me so far.
  • 2 years later...
After importing shading scene from sketchup, simulation is pretty fast.
But it hangs when I want to produce the simulation report.
Precisely, it stuck at page3. It has been several hours since it started.
I am running out of idea. :roll:
