sefirotha Posted May 20, 2015 Posted May 20, 2015 I need to modelize a tracking horizontal N-S axis system.In the orientation module, I set the following parameters:Axis tilt : 0°Axis azimuth : -11°Phi min: -50°Phi max: +50°Backtracking : yesPitch: 3.92mCollector width:1.96mIn the shading scene, I use the same parameter, but I can't change the axis azimuth when backtracking is activated. At the end, I got an error message:"You have defined a tracking plane in the shading scene. All tracking parameters should match the "Orientation" definition.Here, Tilted axis tracking: the axis orientations don't match"With version 6.3.7, we can't avoid using a 3D scene, so what should I do ?
morganluminate Posted January 15, 2016 Posted January 15, 2016 I have this same problem. Did you ever figure out a solution?
