Hennie Posted March 28, 2015 Posted March 28, 2015 Hi,I'm trying to simulate the sensitivity to the Uc, constant loss factor and Uv, wind loss factor.When setting up my batch file, I successfully managed to determine a variance in module temperature due to change in Uc, however any change in Uv does not make any difference to the module temperature.I confirmed that the wind speed is not zero and varies between 0.11 and 8.6 m/s. When making the Uv factor change manually and running single simulations after each change, I do notice a variance in module temperature.Can you please confirm that batch simulation is working correctly for the Uv parameter? Thank you. Kind Regards,Hennie
