aimepinto Posted July 25, 2012 Posted July 25, 2012 Hello,I hope someone can help me.I'm trying to simulate a water pumping system that uses an AC water pump with frequency converter configurated for fixed DC voltage.I'm tried to put this pump http://www.schneider.ind.br/arquivos/download/?id=171&count=1 in the database. But when I'm going to simulate, the m³ in rated head doesn't appear. Also, the treshould curves doesn't showed up in the pump configurator.Someone can help me?
André Mermoud Posted July 31, 2012 Posted July 31, 2012 You are right: I tried to define your pump and did not succeed. There is a problem in the software with the definition of centrifugal pumps using the efficiency as input parameters, that I have to analyse and correct for a next version of PVsyst.
