Is it possible to create a folder under \PVsyst6_Data\ComposPV\PVmodules which is recognizable by PVsyst, to better manage the files? When many versions were created and saved under the same folder, it goes to a mess and not easy to distinguish them.
You are very appreciated for any suggestion or comment. Thanks.
If you do not need all versions you created in all projects, you might want to consider using different workspaces to keep things organized.
See also the Help under 'Technical aspects > File organisation > User data > Workspace'
  • 1 year later...
Dear André,
In the newer version i am not able to find the data path in my hard disk, unless i create or modify a file (eg .pan). Does it exist?
Thanks in advance BR
Dear André,
Hi tecnun,
You can find the workspace path from Files/Workspace, where PVsyst directories and User workspace are listed.
