purnaanshg Posted August 29, 2014 Share Posted August 29, 2014 Hi,I am trying to figure out a way to use multiple PV modules (Eg: Renesola 250W, Trina 230W, Canadian 300W) to design one site. These panels will be constitute separate strings (Eg: X strings of 20 Trina modules each, Y strings of 18 renesola modules each etcetra)Our inverter architecture is distributed with Master/Slave functionality and all these modules will be connecting to one island of "X" inverters with 1 master and "X-1" slaves.Can you please suggest a way to perform the simulation.ThanksPurnaansh Link to comment Share on other sites More sharing options...
André Mermoud Posted August 30, 2014 Share Posted August 30, 2014 This configuration is not possible with PVsyst. The master/slave functionnality is only useable within one given sub-array. This limitation is quite understandable: if you connect your inverters in Master/Slave mode, all the PV sub-arrays will be connected together as a same array. PVsyst (and the best practices of PV) cannot manage heterogeneous arrays, i.e. array with different modules and/or different numbers of modules in series.Be careful with your strings of 20 Trina and 18 Renesola modules in parallel: the operating voltages will not be the same, you will have a significant mismatch, and you can get double Maximum power points, with the risk that the inverter chooses the lower one. Link to comment Share on other sites More sharing options...
