Scuba Posted August 26, 2014 Posted August 26, 2014 Hi PVsyst team,My organisation uses a network location for the PVsyst6_Data directory, so that we can all access the same projects and database files.We experience crippling loading times after many simple actions undertaken in PVsyst:Opening PVsystAfter clicking Load ProjectAfter clicking Site and MeteoAfter selecting a Meteo fileOpening module or inverter windows within SystemNavigating between system variantsetc.Is there anything we can do to improve the situation? Using local user workspaces is not an option – we are a large design team and need the flexibility/security a network directory provides.
André Mermoud Posted August 26, 2014 Posted August 26, 2014 The choice of a project or a meteo file may become slow when the list is long, i.e a common list of projects shared by many people. Because each file of the directory has to be open for extracting information for the list. And this is still made worse if the access is through a network. However this reading is normally done once only for each run of the software. A solution could be to remove the old projects or meteo files (no more in use), i.e. to store them in an archiving data structure. In "Files" / "Workspace", you have the opportunity of easily switch to another data structure.
