Output csv file: values at night time not plausible
When generating a csv output file for "energy injected into grid" the csv file seems to contain wrong values at night time hours (for example: based on selected transformers the no-load losses at 01:00h should be around 38kW [-38.267kW]. However, the corresponding cell shows a value of -38267kW). Could this be an interface problem between PVsyst and the German version of Excel which uses comma instead of point for decimal separation? If so, is there an option to avoid this?
I can't understand that.
Please check (at the top of the column) that the values are not expressed in W instead of kW.
If the problem persists, please send your whole project to Support@pvsyst.com.
