moonlite Posted April 10, 2014 Share Posted April 10, 2014 I'm running version 5.72 and tasked with optimizing a north-south single axis tracker system. However, the results in the reports seem off and there is an bug with the tracker limit, "Phi max". As you can see in the screen clip, the min/max limits are -45 to 45. However, in the report, the maximum limit is a little off. Another odd thing is that when I return to the orientation window, the maximum phi value is 90. Also, in the lower United States, what are the typical gains in production when backtracking is used and the ground cover ratio is about 40%?Thank you, Link to comment Share on other sites More sharing options...
André Mermoud Posted April 10, 2014 Share Posted April 10, 2014 This was an accidental error in the version 5.72, when reading the file. Please update to the version 5.73. Perhaps you will have to redefine correctly the Phi limit if the file was written by the version 5.72. Link to comment Share on other sites More sharing options...
moonlite Posted April 10, 2014 Author Share Posted April 10, 2014 Thank you for the quick reply.Also, in the lower United States, what are the typical gains in production when backtracking is used and the ground cover ratio is about 40%?Thanks again, Link to comment Share on other sites More sharing options...
