buffelkip Posted April 1, 2025 Posted April 1, 2025 Hi, I model utility scale n-type mono crystalline PV modules. I am not sure what settings for Spectral Correction I should use. I am aware that the FirstSolar model is not considered reliable. However, I would like to take into account the Spectral Correction for PV modules in the Sandia Database. To my understanding, even if the module used is not available in the database, a similar module is selected for the spectral correction. Is below the correct way of setting the spectral correction, in this case? Thanks!
Linda Thoren Posted April 2, 2025 Posted April 2, 2025 Hello, The Sandia model is only an option for panels in the Sandia database. You can choose to filter the Sandia Database among the available panels and there you have an option to change to the Sandia model. In your print screen, you have defined the First Solar Spectral correction. By default PVsyst propose no spectral correction for crystalline modules
