Gary Tan Posted March 28, 2025 Posted March 28, 2025 (edited) Hi all, I been learning to use Pvsyst, i recently try to compare my simulation with my friend. In the loss diagram i found that the Irradiation level for both are different. Any other setting or configuration i might need to look at given the location set point is the same. Edited March 28, 2025 by Gary Tan
Linda Thoren Posted March 28, 2025 Posted March 28, 2025 Hello, Indeed, the first input of the Global horizontal irradiation is different between the two diagrams. Verify that you have the same coordinates and are using the same weather data provider.
Gary Tan Posted April 4, 2025 Author Posted April 4, 2025 The coordinate might not be the same exactly but i ensure is the same location.
Linda Thoren Posted April 7, 2025 Posted April 7, 2025 In PVsyst you have the possibility to import weather data from various weather data providers. If you are using the same weather data, indeed the Global horizontal irradiation will identical.
