Israel Pinto Posted March 18, 2025 Posted March 18, 2025 Hello everyone, I need to use the Batch Simulation mode in PVSyst to simulate the annual generation over a 20-year period. This means the same simulation will run 20 times, with the only difference being the accumulated degradation level from one year to the next. My issue is the number of times the Near Shading calculation is performed in the 3D scenario—once per simulation. Is there a way, using Batch Mode, for PVSyst to calculate the Near Shading loss only in the first simulation and then use that value for the remaining simulations? The problem is making the simulation very slow, exceeding three hours. These simulations will consider a 3D scenario of the plant, designed in PVCase and imported into PVSyst. Tank you in advance!
Israel Pinto Posted March 20, 2025 Author Posted March 20, 2025 Hi dtarin. Thanks for feedbak. I don't know this simulation mode? How make that?
Israel Pinto Posted March 20, 2025 Author Posted March 20, 2025 Hi dtarin. Yes, I used the Fast Mode. Tanhks.
Michele Oliosi Posted March 21, 2025 Posted March 21, 2025 Hi ! Which version of PVsyst are you running ? We will make some checks to see if we can reproduce this behavior
Israel Pinto Posted March 24, 2025 Author Posted March 24, 2025 Hi Michele. I'm running the PVSyst 7.4. Thanks.
Michele Oliosi Posted March 24, 2025 Posted March 24, 2025 I see, I have checked and indeed this is not the case. PVsyst 8 also has the same issue. I have created a ticket to fix this in a future patch.
