jonipa Posted March 11 Posted March 11 When defining the loss fraction, PVSyst mentions in the documentation: And when going to the definition of PNom of the inverter: When it says "without temperature correction", does this mean the ohmnic loss fraction to input at PNom(Inv) should be calculated at its maximum power instead of at its nominal power? As an example, it would mean calculating the ohmnic loss at 320kW (Pnom of inverter at 40ºC) or 352kW (Pmax of inverter that happens at 30ºC).
jonipa Posted March 14 Author Posted March 14 @Michele Oliosi @André Mermoud your help is appreciated. Thank you.
Michele Oliosi Posted March 24 Posted March 24 Pnom without temperature correction means nominal power, and not maximum power. So in your example it is relative to 320kW.
