alsolar Posted February 23, 2014 Posted February 23, 2014 Hello. When I try to do a simulation (tools > measure data analysis ), and I load the corect project, when I click in "Site and Meteo" I see the correct Project Site. However, below at the "System Variant" section, in the "meas. data" dropdown, I only have a choice to select a .DAM file from Geneva, so I am not able to run the Simulation with the correct Site. How do I attach the correct Project Site into the "meas. data" drop down? Do I have to convert my Site.MET file into DAM? How do I do that properly so that I can use the correct .DAM file on the Simulation? Thanks and Regards, Al
André Mermoud Posted February 25, 2014 Posted February 25, 2014 This is not the right place for performing PVsyst simulations. You should use (on the main page) : "Project design" / "Grid connected". Here you are in a special (advanced) tool for the analysis of data measured on a PV system. DAM files are meteo files including additional measured data about your system (for example output energy).
