PaulAdrian Posted February 12, 2025 Posted February 12, 2025 Hello, I am simulating a 12.5MWp ground mounted system, the following are the components based on layout: 20160 modules x 620Wp 35 inverters of Sungrow SG320HX -20@50 deg C When I simulate it maintaining a 1.20 DC/AC ratio it can only provide me 11.58MWp, 18676 modules and 32 units of inverters. Kindly advise how I can match the 12.5MWp capacity which is based on the layout and the max cap we can put on the area? Additionally how I can increase the number of my inverters to 35 x SG320HX -20@50 deg C? looking forward to your kind assistance.
Lazare Fesnien Posted February 12, 2025 Posted February 12, 2025 Dear Paul Adrian, I think I didn't quite understand your question. I don't know if you want to maintain the same DC/AC ratio of 1.20 or maintain the PV power ?
PaulAdrian Posted February 12, 2025 Author Posted February 12, 2025 Hi Lazare, I am aiming to maintain the power with 1.2 DC/AC Ratio.
Lazare Fesnien Posted February 13, 2025 Posted February 13, 2025 If you want to maintain the power of the PV field and the ratio of 1.20 then you must act on the number of inverters and the power of the inverters
PaulAdrian Posted February 13, 2025 Author Posted February 13, 2025 Hi Lazare, For example,sub array 1, I wanted to maintain the 4183kWp , however when I click resize, it maintains the number of inverter and increases the DC/AC ratio to 1.3 instead. Please see below: Kindly advise how to work around it and manually increase the number of inverter?
Lazare Fesnien Posted February 14, 2025 Posted February 14, 2025 Indeed in this case, as you need to maintain the DC/AC ratio of 1.20 you must manually modify the number of inverters in order to find the desired ratio
PaulAdrian Posted February 14, 2025 Author Posted February 14, 2025 Noted, it means I have to un-tick the box of " Use multi-MPPT feature"?
Lazare Fesnien Posted February 17, 2025 Posted February 17, 2025 No you can keep this box checked but instead of modifying the number of inverters you will have to modify the number of MPPT input in this case
