ShivamPandey Posted January 18, 2025 Posted January 18, 2025 After importing PVC file, getting this error, "Orientation #2 "Tracking horizontal axis, Azim. 0.0°, Average": No attached subarray in the System part!". But in the orientation tab, every parameter is the same. See below snip. There are two orientations one has backtracking and another with average. I deleted orientation 1 from the 3D scene and all trackers from orientation 1 to orientation 2 with average and selected average from the pop-up received. What is the reason behind it even when all parameters are the same?
Muhammed Sarikaya Posted January 20, 2025 Posted January 20, 2025 Dear Shivam, I need to investigate your project, so could you please send it to us as a zip file at "support@pvsyst.com" by following this process: File - Export projects - select the project Regards, Muhammed Sarikaya
Zoe D. Posted March 12, 2025 Posted March 12, 2025 Hi PVsyst, I have the same issue. What was the solution? Best, Zoe
Muhammed Sarikaya Posted March 13, 2025 Posted March 13, 2025 Dear Zoe, In the system section, you need to create a sub-array for the second orientation and define it. It is also important to assign it to the second orientation. Regards,
