I was wondering if there is any technical manual/doc that describes the the mathematical theory behind the PVsysty simulation.
Especially, I'm curios about whether the simulation uses regression method in power output calculations?
Thanks,
The simulation of PVsyst uses several physical models: irradiance (diffuse from global whern necessary, transposition on tilted plane), shadings, one-diode model for PV module performance, efficiency and power limitation for inverter, different losses, etc.
No regressions are involved in this process. ,
