asanogo96 Posted December 11, 2024 Posted December 11, 2024 Hey, I am seeing this error after I constructed my 3D scene: I am not sure how to address this issue since I manually defined the pitch for each array. I can still run the simulation, but I am curious about how to resolve this issue.
dtarin Posted December 12, 2024 Posted December 12, 2024 PVsyst will often (or always?) default to using the highest GCR under the backtracking menu if you have not selected which tracker(s) to use for backtracking, even if there are only one at say 0.411 vs 0.410. In the shade scene, go into the backtracking menu under tools to select the appropriate tracker for backtracking. There are different options, you can select an individual table (at the pitch you want) or automatic.
Michele Oliosi Posted December 13, 2024 Posted December 13, 2024 dtarin's answer is on point, thanks !
