NabilIrfan Posted December 10, 2024 Posted December 10, 2024 As the title mentioned, I have been trying to integrate the simulation (with aging tools) in economic evaluation. However, seems like I cant integrate the options. Basically what I have done. 1) Run the simulation (without the setting from detailed losses>aging and advanced simulation > aging tools) . What happened here is the simulation from economic evaluation asked me to resimulate with aging tools. 2) However, when I actually resimulate the system with aging tools in by these 3 ways:- - Setting up the aging tools in detailed losses only - Setting up the aging tools in advanced simulation only - Setting up the aging in both detailed losses and advanced simulation It will show the command that say i need to remove the the aging tools from detailed losses. My question is, how to actually use this tools? Ive been trying to figure out for the past few days and I am out of ideas. Appreciate for the response !
Hizir Apaydin Posted December 16, 2024 Posted December 16, 2024 Dear Nabil, Could you please indicate us which version of PVsyst you are using? The second warning message you mentioned should not appear in last versions of PVsyst. We invite you to send your log and project files to support@pvsyst.com for a more detailed analysis. (main menu File>Export logs and File>Export projects) Best regards
