Gustavo Pianovski Posted November 18, 2024 Posted November 18, 2024 Hello, Is it possible to change of LID loss, ground albedo, soiling loss, simulation year and others parameters using PVsystCLI? For example, pseudo sub-hourly simulation with change of simulation year. Thank you!
Michele Oliosi Posted November 18, 2024 Posted November 18, 2024 At the moment, changing the parameters programmatically can only be done via PVsyst (by using the batch mode to create and/or simulate new variants). In the future, we will extend the use of CLI so that parameters can be changed programmatically only using PVsystCLI.
Gustavo Pianovski Posted November 18, 2024 Author Posted November 18, 2024 Thank you Michele! When will this be implemented in PVsystCLI?
Michele Oliosi Posted November 18, 2024 Posted November 18, 2024 Right now we are looking at the next minor version of PVsyst (8.1), but that could still change (before or after) of course.
Gustavo Pianovski Posted October 28, 2025 Author Posted October 28, 2025 Do you have an updated estimate for when this will be implemented?
Michele Oliosi Posted October 30, 2025 Posted October 30, 2025 For most practical purposes, this is already available in the latest 8.0 version. Indeed, PVsystCLI has been made compatible with batch files. In other words, you can call a batch of simulations from PVsystCLI using a batch parameters file. You can find some more details on this page: https://www.pvsyst.com/help-cli/reference/index.html#run-simulation The command that you should look at is --batch-params-file
