PINIT Posted November 5, 2024 Posted November 5, 2024 Please explain why MERC 1300W can t be use with inverter SUN5000-150k-MG0 ?, but the specification sheet specify it is compatible.
Robin Vincent Posted November 5, 2024 Posted November 5, 2024 PVsyst integrates a set of rules, as requested by Huawei, to authorize or not some inverters / optimizers combination. A side effect is that if you create your own inverter it will not be compatible with any Huawei optimizers. You'll be able to use Sun5000 inverters with MERC optimizers in PVsyst8, which should be released in a matter of days or weeks.
