Swonno Posted October 11, 2024 Posted October 11, 2024 Hi Long time no see, I designed with Sketchup and imported to PVSyst with DAE file but the module is dived to one each other when it got imported to PVSyst. Here`s a problem. When I defien partition for electrical loss, I can't becasue it is small portion of size. How can I resolve this problem? Pls guide me Thanks.
Swonno Posted October 14, 2024 Author Posted October 14, 2024 (edited) I try to adjust "According to moducle strings". However, Error message appears. I checked define partition box, Becasue while it comes from Sketchup , every arrays are divied into one segment. So I used to set with array basis for the partition but now I can see only one segment basis defining partition. I want to adjust the electrical shading calculation losses with this situation, What can I do ? I am sorry my english is bad and It might be hard to understand. If you know any idea for this, Pls help. Thanks Swonno. Edited October 14, 2024 by Swonno
Muhammed Sarikaya Posted October 14, 2024 Posted October 14, 2024 First of all, I need to understand whether you have a PV table or just a single PV module. Could you please share your DAE file with us at support@pvsyst.com for further investigation? This will help us identify where the issues are. Regards,
