Dariusz K Posted January 21, 2014 Share Posted January 21, 2014 After moving license and database of all projects and components to the new PC I'm not able to generate report.I got following error message: "Aucune imprimante par default selectionnee" - No default printer?I'm using network printer as default, don't have local one, and I'm not able even to view the report.Any suggestions?RegardsDariusz Link to comment Share on other sites More sharing options...
Dariusz K Posted January 22, 2014 Author Share Posted January 22, 2014 (edited) I get PVsyst to work by installing local printer.But now reports are generated improperly: text is outside page area, as per attached picture. Please help to get it corrected. Edited January 22, 2014 by Dariusz K Link to comment Share on other sites More sharing options...
Bruno Wittmer Posted January 22, 2014 Share Posted January 22, 2014 Did you try the following recipe from the FAQ section?http://forum.pvsyst.com/viewtopic.php?f=17&t=92 Link to comment Share on other sites More sharing options...
Dariusz K Posted January 22, 2014 Author Share Posted January 22, 2014 Yes, I did, that solved problem no 1, but lead to problem no 2 - text outside page area. Link to comment Share on other sites More sharing options...
Bruno Wittmer Posted January 23, 2014 Share Posted January 23, 2014 Could you please check the paper size that is used?The report in your screenshot should fit on an A4 or Letter page. Link to comment Share on other sites More sharing options...
Dariusz K Posted January 23, 2014 Author Share Posted January 23, 2014 Paper size is A4, and it does not fit. Link to comment Share on other sites More sharing options...
Dariusz K Posted January 24, 2014 Author Share Posted January 24, 2014 This is the reason:When changing text size to Smaller (100%) report is affected, when I changed back to Medium (125%) report is displayed and printed properly.Please look into it, and fix the problem, as I definitely prefer Smaller text :roll: Link to comment Share on other sites More sharing options...
