Solar radiation below the semi-transparent PV panels
Hi there,
I would to check if PVsyst presents results of solar radiation that cross semi-transparent PV panels in agrivoltaic system applications (vegetable garden below the solar panels). If not, how could it be calculated?
Kind regards,
Giovani Dávi
When you want to evaluated the irradiance on the ground, you will use the Biacial option.
In the bifacial system definition, you have this parameter:
The ground irradiance calculation will take this parameter into account.
