Jeanne Posted September 11, 2024 Posted September 11, 2024 Hello, I have a problem concerning partitionning. My layout looks like this : I used the Voltec pv pannels that cannot be used with the layout tool, so I used the partitions like this : I end up having more than a 6 % loss for the electrical loss according to partitions: I then changed the pv panels to the Jinko ones, that can be used for the detailed electrical calculation, to compare the loss. I only have a 0.82% loss. How can this be explained ? I may not use the partition tool the right way. Thank you for your answer.
Michele Oliosi Posted September 13, 2024 Posted September 13, 2024 The partition tool is not really adapted to this kind of situation either. For irregular shadings, it tends to overestimate the losses. I would suggest changing the parameter "Fraction for electrical effect" to about 20 %. This will reduce the electrical shading loss so that it has about the same magnitude as the jinko modules. I did not go as far as setting a 10% fraction because it is better to be very conservative in this case.
Loïs Masson Posted September 13, 2024 Posted September 13, 2024 Hello, I have the same problem. Can we use partitions with non-rectangular PV table ? otherwise, is there a another solution with Voltec panels to simulate electrical shading ? Thanks for your response !
Michele Oliosi Posted September 13, 2024 Posted September 13, 2024 Can you also share the voltec module references ?
Loïs Masson Posted September 16, 2024 Posted September 16, 2024 Hello, VOLTEC 126 VSMD 395Wc and 80 VSMP 400 Wc
Michele Oliosi Posted September 16, 2024 Posted September 16, 2024 @Loïs Masson Yes it is possible to use partitions with a non-rectangular PV table. Honestly, with non-conventionally wired modules such as the voltec ones, there are no other solutions with the current PVsyst version. Finding equivalent modules, to run the module layout calculation, and using that to adjust the results of the partition calculation, as suggested at the beginning of the thread, seems like a reasonable idea.
