navdeep4solar Posted September 3, 2024 Posted September 3, 2024 Greetings, While doing a PVSyst simulation for a project having vertical panels(90°) on a ground mount arrangement, I get an unexplainable PR of 122% for the given orientations, also th global incident is in negative. I have attached the PVSyst Report for you refrence, please provied an answer
Jéremie Bernier Posted September 6, 2024 Posted September 6, 2024 Hello, to better assist you with your issue please send the export of your project in zip format to our support : support@pvsyst.com Regards
Michele Oliosi Posted September 6, 2024 Posted September 6, 2024 This is normal, since PR is defined normalized by the front-side POA irradiance (GlobInc) but bifacial modules can also capture light from the back. The PR of bifacial projects is oftentimes > 1. There are more details on this help page: https://www.pvsyst.com/help/performance_ratio.htm Regarding the negative Global Incident, this is also normal, because it accounts for the front side irradiance relative to the horizontal plane. If you just look at the front-side, there is more irradiance on a horizontal plane than on a vertical plane. This is of course more than compensated by the backside irradiance part of the loss diagram.
