Abeer Posted August 18, 2024 Posted August 18, 2024 How can I adjust or control the Inverter Loss over nominal inv. power ?
Linda Thoren Posted August 19, 2024 Posted August 19, 2024 To better understand the different losses in an inverter, please read: https://www.pvsyst.com/help/inverter_operating_limits.htm Large Inverter Losses over nominal inv. power could appears in the case if for instance the number of strings are not a multiple of the number of MPPT inputs or if the power sharing is not activated (with a green "active" light). Please see our tutorial of how to use the multiple MPPT and power sharing in the following link: Kind regards
