JoaoReis Posted July 17 Share Posted July 17 Hi everyone. I'm simulating the terrain in PVSyst. I divided the system into 5 sub-array orientations. In 'Main Parameters>System' I correctly correlated the number of modules for each Orientation with the number of modules in the 3D scene. However, even if the number of modules is correctly listed, the message is displayed as shown in the image below. I am unable to continue with the simulation. I already increased the area of the 3D scene and it didn't work. Link to comment Share on other sites More sharing options...
dtarin Posted July 18 Share Posted July 18 Change your settings in green box below. Link to comment Share on other sites More sharing options...
JoaoReis Posted July 18 Author Share Posted July 18 Hello dtarin. Thanks for your response. I made the changes you suggested. However, it still has the same error. Do you know of any other configuration to be done? Link to comment Share on other sites More sharing options...
Stéphane Posted July 19 Share Posted July 19 Hello JoaoReis. You can send us your project files at support@pvsyst.com so that we can have a closer look and try to help you. You can export the project from the main window > File > Export projects. Link to comment Share on other sites More sharing options...
