qasem Posted July 9, 2024 Posted July 9, 2024 hi dear what is change pnom ration dc: ac in pvsyst ? i will change it 1.10 thanks
Muhammed Sarikaya Posted July 10, 2024 Posted July 10, 2024 Dear Qasem, I invite you to read our help page about the Pnom ratio: https://www.pvsyst.com/help/index.html?pnomratio.htm Regards, Muhammed Sarikaya
qasem Posted July 11, 2024 Author Posted July 11, 2024 dear, thanks for your answer but i dont underestand it can you explain it or take photo of pvsyst ?
Linda Thoren Posted July 11, 2024 Posted July 11, 2024 Hello, The Pnom ratio, also known as the DC-AC ratio, refers to the ratio of the nominal DC power output of a solar panel array to the nominal AC power capacity of the inverter, indicating how much DC capacity is installed relative to the inverter's AC capacity. Thus, the Pnom ratio changes if you adjust the number of panels installed or the capacity of the inverter. Kind regards
