Swonno Posted July 5, 2024 Posted July 5, 2024 Hello PVSyst team, May I have a quesitno about zone feature ? This feature seems like appoingting area so it generates automatically tables fitting well into the area. In this phase , I'm curious is it possible that restrict capacity or module numbers so that can be close to my goal capacity. It is really hard to check the hole 3D capacity by clicking every tables and array and counting those numbers. I just select every tables and type "Ctrl+G" and click export to excel and i calculate module whole numbers in excel (because 3d Batch sometimes it does not perfectly match with system capacity.) So I'm wondering if it is possible. Thank you, Swonno.
Muhammed Sarikaya Posted July 5, 2024 Posted July 5, 2024 Dear Swonno, Unfortunately, this is the weakness of the table zone. It's an iterative process; you need to come back and check the number of PV modules and delete them to reach the desired number. Regards, Muhammed Sarikaya
Swonno Posted July 6, 2024 Author Posted July 6, 2024 21 hours ago, Muhammed Sarikaya said: Dear Swonno, Unfortunately, this is the weakness of the table zone. It's an iterative process; you need to come back and check the number of PV modules and delete them to reach the desired number. Regards, Muhammed Sarikaya Thank you for your reply, I got it! Have a wonderful weekend!
