Pranav Posted June 7, 2024 Posted June 7, 2024 I have consumption data for every 15 mins in excel. Is there any possiblity to import this consumption data in pvsyst
Linda Thoren Posted June 7, 2024 Posted June 7, 2024 Yes it is possible to import a load profile through the self consumption window. For the importing of hourly or sub-hourly parameters in PVsyst, you must use the following standard format: -Text file (CSV format with commas or semicolons). -All lines beginning with the hash symbol '#' are assumed to be comments, and will be ignored. -Blank lines are ignored. -The first line that does not start with #, holds the column titles. The first two columns should be "Date", and "P Load", further columns are ignored. -The following line contains the units of the data in the columns. The date should have no units, the units for the load can be power ([W], [kW] or [MW]) or energy ([Wh], [kWh] or [MWh]). -Then there follow the lines with the values, one line per data entry. -The date and time in the first column can be given either in European format (DD/MM/YY hh:mm) or in US format (MM/DD/YY hh:mm). -The file should contain all hours of a generic year (from 01/01 at 00:00 up to 31/12 at 23:00). Only day and month will be retained, the year will be ignored. -These dates/hours do not need to be related to the dates of your input meteo file: they are for each hour of a generic year. Please also see our youtube tutorial of how to define a self consumption profile in a grid connected system: Kind regards
