Financial Balance button - how to use
How do I un-ghost the Financial Balance button?
I would like to specify a different FIT for different hours during the year, and optimize the array accordingly.
Thanks
The financial balance doesn't make sense without defining the investment of your installation of course.
To get the button active, the energy cost should have a realistic value. You should at least specify the cost of the PV modules and the inverter.
Once this is defined, you can click on the "Financial Balance" button, to get to the dialog "Tarification and Long Term Financial Balance". Here the checkboxes on the top allow you to specify very detailed scenarios for varying FITs.
Thank you Bruno, I was able to activate it using your advice.
In my case, I had to insert some commercial values in the .PAN and .OND parameters.
