MANOS DRO Posted June 4, 2024 Posted June 4, 2024 How can I put 2 or 3 different azimuth of the different string panels in the same inverter
Linda Thoren Posted June 4, 2024 Posted June 4, 2024 Hello, First you define your different orientations using the field type multiple orientations in the Orientation window. In the system window you can create multiple subarrays (see the List of subarrays to the right) and assign each subarray to an orientation (see the list of orientation that you have defined previously, in the Sub-array name and Orientating angle, orientation highlighted in the print screen below). If your inverter has multiple MPPTs input, you can activate the Use multi-MPPT feature and assign a number of MPPT inputs to each sub-array and use the Power sharing feature for sharing of Nominal Power between MPPT inputs of a same inverter. You can find more detailed explanations of the MPPT feature and Power sharing in the following help pages: https://www.pvsyst.com/help/multi_mppt_use.htm https://www.pvsyst.com/help/powersharing.htm https://www.pvsyst.com/help/multi-mppt_more-examples.htm Kind regards
