Pranav Posted May 15, 2024 Posted May 15, 2024 Hello Everyone, 1. I need a perfect analysis for shading affect per Mppt. Like power loss per module per mppt. 2. If I want to show the results in my presentation for the percentages of shadow per module. 3. If I want to print String plan for solar park, For eg. (Inverter.mpp.String.Module Number) in such format or any suitable format from pvsyst. How I can find this 3 features in pvsyst. I hope I will soon here some suggesstions from you. Thank you. Regards, pranav
Michele Oliosi Posted May 16, 2024 Posted May 16, 2024 Hi, Unfortunately, PVsyst can only export variables for the system as a whole. In order to have power losses per MPPT, you need to make different variants with one of the MPPTs only and run the simulation for each of them. This will be very time-consuming, so I wouldn't advise doing it. Same thing for the shade by module, it is not an export value for PVsyst. You need to make a special scene with a single module to get the shading values for a single module. At the moment, in PVsyst, the best in terms of stringing is the single line diagram. However, there is no spatial layout associated with it. You can also print the "Module layout" definitions to color-code the stringing with a spatial layout. However, there is no legend associated to it.
Pranav Posted May 17, 2024 Author Posted May 17, 2024 Thanks for the reply. I have oner more questions regarding power outpur prt mpp as well as per inverters. How can get such results? Thank You. Regards, Pranav
Michele Oliosi Posted May 17, 2024 Posted May 17, 2024 As mentioned, in PVsyst you can only have the power output for a system as a whole. If you need the power output per MPP or per inverter, you should define a system containing only 1 MPP input, or only 1 inverter.
