hello
i have 6.14 versiton
i try to run simulation 42 MWP pannels + 31 MWP inv
this run O.k
if i try to put power limit 31 MW
the simulation do wong data ( i you want i send )
thanks
elad
(elad@sunisrael.co.il)
We cannot say anything if you don't mention which kind of wrong data. Please explain.
the units of limits is in MW
but to run good simulation this is KW
  • 2 weeks later...
You are right.
There is a problem above 10 MW, the unit change doesn't work correctly. You should indeed specify the value in kW although the displayed unit is in MW.
I have corrrected for the next version 6.17.
