Alessander Posted April 30, 2024 Posted April 30, 2024 Prezados, Boa tarde, Estou tendo problemas para a geração de relatório após simular. O software trava no meio do carregamento e não gera. A versão instalada é a 7.4.6 Obrigado
Nils Lang Posted May 1, 2024 Posted May 1, 2024 Dear Alessander, It looks like PVsyst is freezing when it uses your computer graphic card driver. Please email us your PVsyst LOG files (using menu <file> <Export logs>) so we can have a deeper look. In the meantime, you can already try to update your graphic card driver by following the procedure documented in our FAQ: https://forum.pvsyst.com/topic/1253-updating-your-graphics-card-driver-pvsyst-660-and-above/?do=findComment&comment=3402 Alternatively, you can try to run PVsyst with another graphic card driver of your PC if you have one. This selection is available in Windows settings (in Graphics settings) after you have chosen PVsyst program file: I hope this will help you to resolve this issue. Best regards. Nils Lang PVSYST SA - Technical Support
