Mark.Glavan Posted December 9, 2013 Posted December 9, 2013 Hi,Is there any way to tilt a handrail shading object in the XZ axis? For example, I have a handrail running up an inclined walkway adjacent to a PV array. When I adjust the object tilt in PVsyst it only tilts the handrail in the XY axis (as if it were tipping over) rather than the XZ axis. This would be a very handy feature to have, as I imagine several PV installations would be on inclined rooftops with shading caused by handrails. Regards,Mark
Bruno Wittmer Posted December 9, 2013 Posted December 9, 2013 Hello Mark,one way to do it is to create the handrail as a composed object. You choose an azimuth of 90° for the handrail inside the composed object. When you now "close and integrate" the composed object, the tilt you choose for positioning it in the main scene will tilt the handrail along the good direction as shown in the screenshot.This solution has two limitations:1. You cannot group the handrail with the roof, so you have to figure out how to position the handrail in the main scene , so that it matches the inclination and orientation of the roof.2. The vertical poles of the handrail will also be tilted.If this is not too much of a limitation for you, this should do the job.Best regards, Bruno Tilted handrail
mut Posted November 14 Posted November 14 Hallo, can you give more explaination about handrail tilt. I cant get it
Bruno Wittmer Posted November 25 Posted November 25 In the 3D editor, please follow these steps: 1. 'Create -> Building/Composed Object' 2. Go to 'Add Object' and create the Handrail 3. After closing the 'Elementary shading object' window with the handrail, but still in the 'Building / Composed object' window, apply an azimuth of 90° to the handrail. 4. Now close the 'Building / Composed object' window, coming back to the main window of the 3D editor 5. If you now apply a tilt to the handrail, it will rotate like in the screen shot above.
