mohamed abdelkader Posted February 15, 2024 Posted February 15, 2024 Hello , i am trying to perform a calculation with a bifacial panels but they shall be mounted on a fixed structure . in order to enable bifacial calculation it requires to enable unlimited trackers which is not the case . so how can i consider bifacial calculation with a fixed structure system
Muhammed Sarikaya Posted February 16, 2024 Posted February 16, 2024 Dear Mohamed, You can conduct your project with the panels mounted on a fixed tilt plane. To enable bifacial calculations for a fixed structure system, activate the bifacial model and then select 'Use Unlimited Sheds 2D-Model'. Regards, Muhammed Sarikaya
