n.ragavander Posted February 13, 2024 Posted February 13, 2024 How do you get exact polygon lengths? How do you toggle the distance function for a more prescise polygon? For example i have a polygon with specific dimensions how can i use these dimensions while constructing it for the near shading analysis
Hizir Apaydin Posted February 15, 2024 Posted February 15, 2024 On 2/13/2024 at 3:02 PM, n.ragavander said: How do you get exact polygon lengths? How do you toggle the distance function for a more prescise polygon? For example i have a polygon with specific dimensions how can i use these dimensions while constructing it for the near shading analysis Dear N.Ragavander, There are many ways of sizing objects and areas in PVsyst 3D scene. The measure tool of the 3D scene also allows you to make precise measurements of your areas and objects: https://www.pvsyst.com/help/near_shadings_persp.htm If you already have a 3D modelling of your photovoltaic field, you can simply import it in PVsyst. You will then have the expected sizing, without needing to make any modification in PVsyst. Please have a look at our detailed PDF tutorial on this subject: https://www.pvsyst.com/wp-content/pdf-tutorials/pvsyst-tutorial-v7-export-to-pvsyst-en.pdf You can find in the following link the list of supported file formats: https://www.pvsyst.com/help/sketchup.htm If you have a scaled image of your area, you can import it in PVsyst as a ground image and draw a zone on it by superposition, precisely following the outline of the image: https://www.pvsyst.com/help/ground_image.htm https://www.pvsyst.com/help/zones_of_tables.htm Regards
