Niko Posted January 30, 2024 Posted January 30, 2024 I'm getting errors that says: Orientation #2: The area of the 3D fields is lower than the area of the modules defined in the system subarrays. Orientation #3: The area of the 3D fields is lower than the area of the modules defined in the system subarrays. But according to the Compatibility with orientation and system parameter section it is exactly the same, as shown on the picture i attached. And when i press 'system overview' it says like this: Compatibility between System and Shadings Orientation #1 tilt/azim = 30° / -22° 2 sub-arrays PNom = 110 kWp, modules area = 521 m² shading 3D fields 12 tables, total rough area = 521 m² Orientation #2 tilt/azim = 30° / -22° 2 sub-arrays PNom = 110 kWp, modules area = 521 m² shading 3D fields No shading 3D fields defined Orientation #2: The area of the 3D fields is lower than the area of the modules defined in the system subarrays. Orientation #3 tilt/azim = 30° / -22° 2 sub-arrays PNom = 110 kWp, modules area = 521 m² shading 3D fields No shading 3D fields defined Orientation #3: The area of the 3D fields is lower than the area of the modules defined in the system subarrays. System parameters 6 sub-arrays defined Sub-array #1 Sub-Array #1 Orientation #1 Tilt/Azimuth = 30.0° / -22.0° PV modules: 10 strings of 17 modules in series, 170 total Pnom = 545 Wp PNom array = 93 kWp, area = 438 m² Inverters (110 kWac) 7 MPPT inputs, Total 86 kWac, Pnom ratio = 1.08 Sub-array #2 Sub-array #2 Orientation #1 Tilt/Azimuth = 30.0° / -22.0° PV modules: 2 strings of 16 modules in series, 32 total Pnom = 545 Wp PNom array = 17 kWp, area = 83 m² Inverters (110 kWac) 2 MPPT inputs, Total 24 kWac, Pnom ratio = 0.71 Sub-array #3 Sub-array #3 Orientation #2 Tilt/Azimuth = 30.0° / -22.0° PV modules: 10 strings of 17 modules in series, 170 total Pnom = 545 Wp PNom array = 93 kWp, area = 438 m² Inverters (110 kWac) 7 MPPT inputs, Total 86 kWac, Pnom ratio = 1.08 Sub-array #4 Sub-array #4 Orientation #2 Tilt/Azimuth = 30.0° / -22.0° PV modules: 2 strings of 16 modules in series, 32 total Pnom = 545 Wp PNom array = 17 kWp, area = 83 m² Inverters (110 kWac) 2 MPPT inputs, Total 24 kWac, Pnom ratio = 0.71 Sub-array #5 Sub-array #5 Orientation #3 Tilt/Azimuth = 30.0° / -22.0° PV modules: 10 strings of 17 modules in series, 170 total Pnom = 545 Wp PNom array = 93 kWp, area = 438 m² Inverters (110 kWac) 7 MPPT inputs, Total 86 kWac, Pnom ratio = 1.08 Sub-array #6 Sub-array #6 Orientation #3 Tilt/Azimuth = 30.0° / -22.0° PV modules: 2 strings of 16 modules in series, 32 total Pnom = 545 Wp PNom array = 17 kWp, area = 83 m² Inverters (110 kWac) 2 MPPT inputs, Total 24 kWac, Pnom ratio = 0.71 3D shadings parameter 12 field(s) defined Total area 1563 m² Field #1: table Table Row#2 Col#4 Orient.#-2 Total area = 118.6 m² Orientation #1 Tilt/Azimuth = 30.0° / -22.0° Field #2: table Table Row#3 Col#4 Orient.#-3 Total area = 118.6 m² Orientation #1 Tilt/Azimuth = 30.0° / -22.0° Field #3: table Table Row#2 Col#1 Orient.#-2 Total area = 134.1 m² Orientation #1 Tilt/Azimuth = 30.0° / -22.0° Field #4: table Table Row#2 Col#2 Orient.#-2 Total area = 134.1 m² Orientation #1 Tilt/Azimuth = 30.0° / -22.0° Field #5: table Table Row#2 Col#3 Orient.#-2 Total area = 134.1 m² Orientation #1 Tilt/Azimuth = 30.0° / -22.0° Field #6: table Table Row#3 Col#1 Orient.#-3 Total area = 134.1 m² Orientation #1 Tilt/Azimuth = 30.0° / -22.0° Field #7: table Table Row#3 Col#2 Orient.#-3 Total area = 134.1 m² Orientation #1 Tilt/Azimuth = 30.0° / -22.0° Field #8: table Table Row#3 Col#3 Orient.#-3 Total area = 134.1 m² Orientation #1 Tilt/Azimuth = 30.0° / -22.0° Field #9: table Table Row#1 Col#4 Orient.#-1 Total area = 118.6 m² Orientation #1 Tilt/Azimuth = 30.0° / -22.0° Field #10: table Table Row#1 Col#1 Orient.#-1 Total area = 134.1 m² Orientation #1 Tilt/Azimuth = 30.0° / -22.0° Field #11: table Table Row#1 Col#2 Orient.#-1 Total area = 134.1 m² Orientation #1 Tilt/Azimuth = 30.0° / -22.0° Field #12: table Table Row#1 Col#3 Orient.#-1 Total area = 134.1 m² Orientation #1 Tilt/Azimuth = 30.0° / -22.0° Orientation #1 12 tables, Area = 520.9 m² Orientation #1 12 tables, Area = 520.9 m² Orientation #1 12 tables, Area = 520.9 m² Use in simulation: Detailed electrical loss using Module Layout How to fix this?
Stéphane Posted January 30, 2024 Posted January 30, 2024 It looks like the total area is matching between the 3D scene and the System window but it does not match for Orientation #2 and #3. If you can't fix it you can send us your project zip file by email to support@pvsyst.com so that we can have a look.
