Vera Posted January 12, 2024 Posted January 12, 2024 (edited) I need to determine the total length of a tracker. In order to do i so I'm attempting to determine the spacing between modules on a tracker. Although the tracker settings display a module spacing of 0.02, there seems to be a discrepancy when I zoom in and use the measuring tool, as it shows a measurement of 0.05. How could this be? Thank you, Edited January 12, 2024 by Vera
Stéphane Posted January 15, 2024 Posted January 15, 2024 Hello, From your screenshots it looks like you are measuring the distance between two trackers and not the distance between two modules within the same tracker. If you double click on a tracker it will open its details window. There you can go to the "Trackers sizes" tab and look at the width and length of the sensitive area. Then you just need to add the size of the frame to know the full size of your trackers. I hope this helps.
