ShivamPandey Posted January 3, 2024 Posted January 3, 2024 (edited) I am doing a project where I tried to do the simulations with the power-sharing to distribute power equally among the MPPT but I am getting below error "The sum of power shares is larger than 100%". I have attached the images for your reference. First snip shows the list of sub-arrays and system equipment. Below snip is after the power-sharing defined No error in the system after power sharing is done. I can simulate the system without any error But when I go back to the project page I get the error "The sum of power shares is larger than 100%" Please see the below snip. Now, if I go to power-sharing again percentage is changed for each MPPT, and Pnom ratio is uneven instead of equal or near to equal. Now If I uncheck and check, power sharing works fine but sharing is not retained after simualtions. As of now, I have done the simulations with partial sharing but can you please suggest a solution? I can provide more info if needed. Edited January 3, 2024 by ShivamPandey
Michele Oliosi Posted January 3, 2024 Posted January 3, 2024 Hello, Are you running the latest version of PVsyst ? If yes, if you can send your project at support@pvsyst.com, that would greatly help us in figuring out the issue or bug. Thanks in advance
ShivamPandey Posted January 5, 2024 Author Posted January 5, 2024 On 1/3/2024 at 7:26 PM, Michele Oliosi said: Hello, Are you running the latest version of PVsyst ? If yes, if you can send your project at support@pvsyst.com, that would greatly help us in figuring out the issue or bug. Thanks in advance Shared via email
Michele Oliosi Posted January 5, 2024 Posted January 5, 2024 After analyzing your project, I have found that most of the sub-arrays in your system are in an erroneous state, i.e., they do not have the “power-sharing” flag activated. This may happen, for example, if you defined the “power-sharing” once but then switched to not using the multi-MPPT feature at some point. An easy way to correct the state of all sub-arrays is to go to the “power-sharing” window, and click twice on the power-sharing checkbox to deactivate and reactivate it. This will reset the flag for all concerned sub-arrays. On our side, we will try to fix the program to make sure that these situations do not happen anymore.
Bruno Wittmer Posted February 13, 2024 Posted February 13, 2024 The problem has been fixed in PVsyst V7.4.6 that will be published in the coming weeks.
