RicardoMoreno Posted December 5, 2023 Posted December 5, 2023 (edited) Hi, A colleague recently left our company and he left all his PVsyst projects in a zip file. When I try to import them I see this, but it's like an image, I can't select any projects or scroll down the list: I am able to click the Navigate, Import or Close buttons, but as mentioned, I can't select any of the projects. Any suggestions on how to import these projects would be most welcome. Thanks and regards, Ricardo Edited December 5, 2023 by RicardoMoreno
Nils Lang Posted December 5, 2023 Posted December 5, 2023 Dear Ricardo Moreno, In order to investigate the issue you reported, we would need the log files that PVsyst generated on your computer. For this, please follow the following steps: - go to menu Files > Export Logs - check if the Export path is convenient for you, if not choose another place to save your log file with the "Browse" button. - click on "Export" button (your zip log file will be save where it is indicated at Export path field) - attach your zip log file to your email and send it to us using our support address: support@pvsyst.com Best regards.
