Filimena Posted November 14, 2023 Posted November 14, 2023 Good evening, I'm trying to make a PV system combination of horizontal and vertical modules and to get one report (how they react in the same system). I am using "several orientations" in "Orientation" and in attached picture you can see that in "System" I'm defining the orientations as subarrays 1 & 2. The first orientation is with tilt 22 degrees and 0 degrees azimuth and the second is with tilt 90 degrees and azimuth 90 degrees. The PV modules in "Near shadings" are added as arrays of tables. Can you please tell me how to solve this problem with using bifaciality, because is the most important thing in vertical tilt PV modules. Thank you
Michele Oliosi Posted November 16, 2023 Posted November 16, 2023 Hi, At the moment, the bifacial model for the backside irradiance works only with a single orientation. You will have to split your system into two variants.
Filimena Posted November 16, 2023 Author Posted November 16, 2023 2 hours ago, Michele Oliosi said: Hi, At the moment, the bifacial model for the backside irradiance works only with a single orientation. You will have to split your system into two variants. Thank you for the response
