69071800 Posted October 2, 2023 Posted October 2, 2023 When I try to import the fixed table design from pvcase to pvsyst, the software reads the file with some azimuths of -88.9º I draw the design normally, as I have done many times before, according to the actual site. However, when I try to import it into PVSyst and adjust the orientations, it appears as if the tables are rotated in the drawing. But they are not, if I try to manually adjust it, then it becomes rotated. Have you ever seen this happen? Do you know any way to solve the problem? I look forward to your response
Stéphane Posted October 3, 2023 Posted October 3, 2023 Hi, Thank you for reaching out. Can you please send us the PVC file you are trying to import at support@pvsyst.com so that we can try and see what the issue is? Thanks in advance. Regards
