During several projects and while using fill zone option in the shading scene, it results in some panels as shown in the image below highlighted in red are duplicating  existing panels and are located always on the first panel in each row.Those panels messes up the total amount of area used because it adds unnecessary panels and those duplicates also causes a problem in calculating the shadings and the program informs me that i should delete them manually to continue with the calculations which takes a lot of time for huge projects..I don´t want to disable field interpretation check in the tools menu, so my question is am i doing something wrong, or is there an option I am missing to prevent this bug from happening. How can i solve such problem.
Thanks in advance
Dear Mohammed Abou Ghadir,
Thank you for reaching out. Can you please send us your project at support@pvsyst.com so that we can have a look and this strange behavior and try to find a solution ? Thanks in advance.
Regards,
Stéphane
