Nicolm Posted September 15, 2023 Posted September 15, 2023 Hello guys, I have installed the PVsyst version 7.4 and I need to upload an OND file for the inverter SUN2000 115kTLto run a simulation, but without any success. What do you recommend? Thanks
dtarin Posted September 15, 2023 Posted September 15, 2023 Place the OND file here, restart PVsyst \PVSyst Projects\PVsyst7.0_Data\ComposPV\Inverters
Nils Lang Posted September 18, 2023 Posted September 18, 2023 Instead of restarting PVsyst, you can refresh your databases using menu <File> <Refresh databases>. You can also directly import your inverter file in PVsyst using menu <File> <Import components> <Import components from a folder>. You can find more detailed information about this command in PVsyst help: https://www.pvsyst.com/help/index.html?file_import_projects_and_components.htm Best regards.
