Slight edit to "IL" variable names in PVsyst Help Menu
Slight editorial suggestion to add the underscore "_" to the IL variable names listed in the PVsyst Help Menu, e.g., here:
https://www.pvsyst.com/help/simulation_variables_grid.htm
In all cases where PVsyst variable names are listed in the Help Menu, I hope the variable names are listed in the exact same syntax (spelling, capitalization) as what's used in PVsyst (e.g., what's visible to the PVsyst user in the software program, in the output files, etc.). Thanks.
  • 1 month later...
A couple more observations in addition to what I listed above:
- Change E_GridApp to EApGrid [1]
- Change E_Regrid to E_ReGrid [2]
[In general, I'm surprised these modeled data variable names, which appear in the PVsyst 8760 CSV output file, don't follow the existing, preceding "E_Grid" naming convention (e.g., "E_GridApp", "E_GridRct", "E_GridLim"), but O-K.]
Thanks.
[1] https://www.pvsyst.com/help/index.html?power_factor.htm
[2] https://www.pvsyst.com/help/simulation_variables_grid.htm
In the Power factor page, I thought that in this context the name E_GridApp  is more explicit than EApGrid.  This is here a generic value, nor supposed to correspond exactly to the PVsyst variables.
The variables acronyms were chosen at the beginning of PVsyst (1992), with the constraint that they shoiuld not exceed 7 characters.
